How do I zero the signal?
Hi!  This is my first programming project (LabVIEW or otherwise), and I think know what I want, but I don't know how to do it.
I am graphing and recording the displacement of a laser, and I want to be able to "zero" the measurements when I press a button.
Right now, I'm using the Basic Serial Read Write.vi from the examples, only I added a waveform chart so we can see the displacement change in real time.  It works and plots the output from the laser sensor, but I want to be able to hit a button that captures the displacement at that moment to create a reference and subtract it from the signal as it streams in and graphs the difference between the two.   I don't know how to actually do this in LabVIEW, or if this is the best way to do it, but I'm open to suggestions!
Any help is greatly appreciated!
(4,288 Views)
you could zero the graph:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,286 Views)
Harold I think you missed what he was trying to do.
@OP: You are trying to calibrate the machine to subtract a baseline value, correct?
Take a look at the attached VI and see if it is what you wanted.
Cory K
(4,258 Views)
thanks cory, I think I read it a bit to fast lol
Harold Timmis
htimmis@fit.edu
Orlando,Fl
(4,252 Views)
Its alright, reading and writing are for text programmers anyway Smiley Very Happy
Cory K
(4,230 Views)
Thanks Cory 🙂
Message Edited by kyoha on 09-23-2009 01:53 PM
(4,199 Views)
