How do You Change Case Structure from True/False to String Control?
Excellent. I have gotten that to work. Now if I need to add something to the Type Def. What is the proper way to do it so every where that Type Def is used it will update?
Message 11 of 12
(2,227 Views)
Once you have saved the control as a type def, it should automatically update any code that uses that type def.
This Nugget on Type defs may help.
Ben
Message 12 of 12
(2,220 Views)
