How do call Windows XP'scalculator and tackle it on front panel of LabView?
Dear all,
I would like to call Windows XP's calculator and tackle it on front panel of LabView.
Who can help me ?
Best regards ,
 Jun
(2,864 Views)
Running the calculator from LV is easy by using the System Exec VI. Of course, you will then have it as a seperate window.
As far as I know, there is no ActiveX container for the calculator, but you might be able to find one which will let you put "anything" into it and then use that one to run the calculator.
Another option would be to run the calculator application and then embed its window into your FP window. If you search the forums for "MDI" you should find some examples on how to do this.
___________________
Try to take over the world!
(2,838 Views)
Thank you very much !
(2,830 Views)
