How do change UI during run time?
Manual mode ONManual mode ONPID mode ONPID mode ON
I have a toggle that switches between PID and manual modes. When it's in the manual mode, I want certain displays to go away so as not to distract the user with irrelevant info. All this should happen while the program is running.
Can I do that?
(3,659 Views)
Create property nodes for the controls you want to hide and set their visible state to false. Set it to true when you want them to appear again.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,654 Views)
I might use a tab control.
(3,652 Views)
Accepted by topic author MyLord
All Front Panel Controls and Indicators have a Boolean property called "Visible".  The easiest (and least "messy") way to get the Property Node is to right-click on the Control or Indicator in the Block Diagram and choose "Create", then "Property Node".  Click the little selector at the bottom of the Node, find "Visible", right-click the Node and change to "Change to Write" or "Change All to Write" (by default, the node is in "Read" mode, the connector is on the right, and you want the connector on the left so you can "write", or set, it), and wire "T" or "F" to make the Control Visible or not.  An "invisible" control is not affected by clicking on the Front Panel.
Bob Schor
(3,651 Views)
I would also consider a tab control. If you are using the property nodes, remember to only call them when their input changes and not with every iteration of the top-level loop.
(3,579 Views)
