How do create an analog signal from a text or binary file?
I'm trying to output an analog signal from a file on an NI-DAQ 6251 card using labview 8.5. I've found the examples on building a waveform, but I'm stuck at how to read a text file and make a 1-D array to input my amplitudes into the buildwaveform.vi and I can't find any information on how to do so. Any help or direction is greatly appreciated.
thanks,
David
(2,810 Views)
Accepted by topic author LSUgrad85
If all that you want in the file is the Y values, then a text file with a value on each line could be read. The Read From Spreadsheet File can be used. It will return a 2D that you can then use the index array function to get a column or if you select Transpose, the returned 1D array would be used.
If you want to create an example, use a 1D array constant in a VI and pass it to the Write to Spreadsheet File.
(2,806 Views)
