How do i Extracting the From the graph using Cursor?
Hi NI,
               I am doing data logging using Write TDMS.vi. The data i am getting say as a array, using build wave form i wired with Write TDMS.vi, where i specified that  t0 and dt.
After complete my data logging i read the data using Read TDM.Vi.
here i want to extract the graph using Cursor's, where i between the time to place these two cursor.  then the extracted portion will be displayed on another graph......
how to do this...?
Balaji DP
(2,867 Views)
Hey,
Attached VI will give you an example how to deal with cursors to get out a certain part of data and display it in another graph.
You might need to change some things, however it shows the basic steps.
Christian
(2,855 Views)
