How do i adjust the margins of the front panel and the diagram.
I have tried to reduce it with the page setup. It does not seem to work.
(2,661 Views)
You can use vi server, and get and set front panel size using property nodes.
Hope this helps
(2,661 Views)
When i use property nodes to set front panel size, the size of the panel window changes but the left, right,top and bottom margins inside the window are not changed. iam interested in changing these margins. Can anyone help.
(2,661 Views)
Use the VI Class property FP.origin. This controls the origin, the
scroll position of the VI panel. You probably want to read it,
modify it, and write it back.
Greg McKaskle
(2,661 Views)
