Looking in the vi diagram you will find Counter Source (stc).vi (immediately to the right of Counter Group Config.vi), that uses as an input a cluster located off to the left on the front panel of Measure period.vi. This cluster contains an option to set the internal timebase used: choose the desired 100 kHz.
Next delete the Counter Get Attribute.vi with the internal Max Timebase constant wired to the Attribute ID input and wire a (double)constant of 100000 to the Y terminal of the division at the far right of the diagram.
That's all.
Roberto
