How do i avoid rounding
I am trying to subtract an array of very small numbers from 1. The resulting output ends up rounding up as an array of 1s. I am expecting to get numbers very close to 1 (say 0.9999999997 for exampe) but not exactly 1.  I have tried to ensure that both inputs to the numeric operator have the same type DBL/SGL etc. I have also tried scaling both inputs up and dividing after.
I know this must be easy but I dont have a ready solution  🙂  VI attached. I need both probes 64 and 65 to maintain a good number of precision digits. Thanks.
[BADGE NAME]
(5,983 Views)
As you didn't store your "very small numbers" as default values, the attached VI doesn't show much except the code itself.
However, your numeric control/indicator is still in default configuration for showing 6 digits of precision. You might want to increase that in the controls/indicators property dialog to show e.g. 15 digits of precision.
Norbert
Norbert
Expert: Geometry
(5,973 Views)
Increase the digits of precision
to get
Ken
(5,963 Views)
  • When attaching an example VI, make sure the controls contain typical default data so we can see what you are talking about.
  • Not the cause of your problem, but mind your representations. that "1" diagram constant should be DBL, not SGL. Notice the coercion dot?
  • DBL values have a precision of about 15 decimal digits. You seem to be worried about the displayed precision of controls and indicators.
  • The displayed precision is only cosmetic and you can change the display format to anything you want (right-click...display format"). The display format does not affect the underlying data, so if you would square the result and subtract  from 1 again, you would get the original data back (within the limits of DBL computations). Try it.
  • Your VI does not contain any "probes", but if you want a probe that shows values with higher precision, you can create custom probes.
  • You cannot change the format of execution highlighting.
(5,953 Views)
