How do i change the data type of Waveform Graphs control from DBL TO SGL
Labview version is 2017
The default data type of Waveform Graphs control is DBL
I cant find a way to change it
(3,881 Views)
Accepted by topic author Bat-Freak
You just need to wire a SGL array to the graph...
(3,877 Views)
But it wont help the memory man'agement🤔
(3,869 Views)
Why not? The graph is polymorphic and will therefore choose the implementation based upon the connected input. If you connect the SGL you will see that it does not create a coercion dot - it changes to SGL instead.
(3,816 Views)
Hi Freak,
Which "memory management" are you talking about?
What is the goal behind your question about using SGL with graphs?
(You might run into other "memory management" troubles as many math functions only support DBL and no SGL, resulting in coercion dots in other places in your code…)
(3,801 Views)
A waveform graph accepts a very rich collection of different input and will adapt whenever a suitable type is wired to it (See below).
(When you say "control", I assume you actually mean "indicator". A graph as control makes little sense!)
Before you wire anything to it, it contains no data, and consumes no data memory!
A waveform graph accepts many datatypes without coercion. Here's a (incomplete) list.
  • 1D numeric array (all integer (I8..U64) and floating point types (SGL..EXT) except FXP and complex)
  • 2D numeric arrays of these types
  • A cluster of three elements (offset, multiplier, and 1D or 2D data as above)
  • A 1D array of such clusters
  • A waveform
  • An array of waveforms
  • dynamic data
(3,790 Views)
