How do i clear a waveform chart after i press stop?
I attached what I have so far.
I'm taking readings from 3 thermocouples simultaniously.
I then graph and log the data in real time.
I would like it if after i press stop, the graph resets. Then when i press start, the graph starts from the beginning.
Any ideas how to do this?
Cory K
(5,601 Views)
The property node has an entry for the chart history. Wire an empty array to clear it, or any other values to initialize the history. There are also examples in examples/general/graph that show how to do this and other things with graphs.
There is a code example here
In this link  there aare examples of clearing a graph/chart by pressing a button.
Message Edited by JoeLabView on 05-27-2008 12:35 PM
(5,595 Views)
On the False side of your measure case, use a Property Node for each chart.  Property should be History Data, set it to write, and wire an empty array to it.  This will clear the graph.  I'd also use a shift register wired to a boolean so that you don't keep writing to the properties.  Set the boolean to true on the True side of your measure case.
Message Edited by Mythilt on 05-27-2008 12:39 PM
Jon D
Certified LabVIEW Developer.
(5,593 Views)
thanks
that worked really well
Cory K
(5,555 Views)
