How do i count different characters from a text.
I have got another question, is it possible to change the text automaticly on the upper right side of the graph?
I attached a picture of what I mean.
Message 21 of 30
(1,917 Views)
The point of the In Place Element Structure is to get the value in a specific index (in our case, corresponding to the letter), increment it, and write that value back into the array.  The In Place Element Structure allows us to do this "in place", meaning the entire array doesn't need to be copied just to update this one element.
And the text you are referring to is the Plot Name.  That can be set with a property node.
Message 22 of 30
(1,904 Views)
I have searched it and found about the property node but I don't understand the function Smiley Surprised
How can I make the background of the graph completely white and automaticly change the text in the little box?
Message 23 of 30
(1,899 Views)
These should be the properties you need.  Go ahead and play with them and see what happens.
Message 24 of 30
(1,889 Views)
Jenson94 wrote:
How can I make the background of the graph completely white ...
If the background color should be white permanently, you would just use the coloring tool in edit mode, no property nodes needed. You only need property nodes if the color needs to be changed at run time. Does it?
If it should be completely white, you should also remove the grid lines.
Message 25 of 30
(1,867 Views)
@Jenson94 wrote:
The part of the in place element structure!
In the old days (i.e. before the in place element structure was available), you would have used index array to get the current count at the specified index, add one to it, and then write it back to the same index using "replace array subset". This operation also occurs "in place", so there is no real penalty compared to the shown solution. They are equivalent because the compiler is smart enough ;). The solution using the in place elements structure is just a little cleaner looking, that's all. 😄
Message 26 of 30
(1,855 Views)
I'm almost finished with the program.
Got one more question, how do i hide a diagram if it has got nothing to show? I would like to hide the diagram if there is no text  in the string.
Message 27 of 30
(1,849 Views)
What is a diagram?
Message 28 of 30
(1,844 Views)
sorry, wrong term I mean I want to hide my waveform graph haha
Message 29 of 30
(1,841 Views)
I guess you're talking about the graph, use a graph property node to set the visible property.
Ben64
Message 30 of 30
(1,839 Views)
