How do i get my waveform graph to plot all points that are sent to it in sequence and not just the latest point?
Sorry I have to go today. I will help again tomorrow when I get back. I hope that everything goes well with out my help.
Tim
GHSP
Message 81 of 87
(862 Views)
@Kenneth22 wrote:
Not sure why but now it seems to work.
It is because the controls were already initilized. If you shut it down completely and restart it it would fail again. The change that I made should fixit it.
Tim
GHSP
Message 82 of 87
(859 Views)
Do you know why my xy graph is not resetting after each cycle?
Message 83 of 87
(841 Views)
Did you have any idea why The xy graph would not be resetting? I have this new version and I didnt implement those last changes you made as I have not had any problems but this one.
Kenny
Message 84 of 87
(822 Views)
When is it not reseting?
Tim
GHSP
Message 85 of 87
(815 Views)
I would like it to reset in between cycles. So when it is looping through cycles I would like it to only have the current cycles data on the graph.
Message 86 of 87
(812 Views)
If you add a local Varible for the graph to this part of the code and clear it it should do what you want.
This would also work (I think) without the need for a loacl variable.
Tim
GHSP
Message 87 of 87
(804 Views)
