12-29-2014 02:04 PM
My goal is to measure and display 8 current and voltage meaurements on the same graph using the daq 6210. Unfortuanetly i cant get it to run and i get the error 50103. I have replaced daq assistant vi which hasnt helped eliminate the problem ..
>>File attached
any suggestions?
12-29-2014 02:16 PM
Probably a good idea to review the Waveform chart examples included in LabVIEW Examples.
12-29-2014 03:42 PM
1. Only set up your task once before your loop. Clear the task after the loop.
2. You can have multiple channels in a DAQmx Task.
3. Do not use the Dynamic Data Type. A simple Index Array would do what you did to get it down to a single channel.
4. A chart keeps a history. You just need to set the value of the chart with the new values.
5. Your building of your XY graph should probably be done after the loop.
6. Do not use references to controls to set values of controls. In this case, just use a wire to pass the data out of the loop.
12-30-2014 04:21 PM
Really appreciate your feedback,..
1) Able to setup the task outside of the loop. UNABLE to clear the task.
2) Added an extra one and will repeat for 6 other loops.
3) Changed successfully with no broken wires
4) do you mean "Array_x1"/x2 on the front panel? If so i have manually filled in the x values.
5) Added a case structure, but the first case depends on the second.
6) are you talking about the Voltage? How exactly should i wire it out?
Changes attached.
01-04-2015 09:48 PM
Can you post your VI in 2013 version?
01-05-2015 02:02 AM
This thread was continued here!
Haab: Please don't create new threads for old problems, stick with one thread!
@jchow: You will find a snippet of that code in the other thread…
