How do i output the sinewave generated in xilinx dds through NI 5781 adapter
I would like to know whether i can directly output the sinewave generated in xilinx dds to NI 5781 adapter module IO. iam using a 7966 flexrio fpga card.
I have gone through the example of 5781. there i found the waveform is generated using buffer memory.
My application needs a xilinx dds to generate the varying sinewave signals and output to NI 5781 IO directly.
please help me in this issue.
Message 1 of 1
(2,543 Views)
