How do i pass a parameter into a labview executable?
I'm using LV 8.2. I compiled my Labview program into an executable. I want to pass in a string parameter when I spawn my executable.
lv_code.exe /name="Test case 1"
How can I make this work? At the very least is there a way I can get my executable to ignore /name?
Shok
(3,115 Views)
This is documented in the LabVIEW Help.
To pass user-defined arguments enter two hypens (--) surrounded by spaces before the set of user-defined arguments. Use the  Application:Command Line Arguments property to get the arguments from within the application.
(3,105 Views)
