How do interrupt cycles and sequences before they end ?
Hello good day, I 'm new to the world of LabVIEW and I 'm doing a program that controls sequences LED lights, considering five sensors, something like traffic lights, the problem that I have is that sequences program takes around 2 minutes to finish , so that between the other logical sequence according to the information they send the sensors, but much time is lost between ending a string and the other begins, my question is: How do I achieve that sequences interrupted and moves to the following without the whole itineration data is completed ? for example if two sensors are activated to begin its sequence, but are turned off and the other 3 are activated before finishing the above sequence is interrupted and start with the new, to save time between sequences. I hope you can help me.
(2,949 Views)
Perhaps show us some of your current code will help illustrate what you are trying to do.  It sounds like a simple State Machine should do the job.
(2,947 Views)
