10-23-2009 10:39 AM
Hey guys,
I have a Waveform Chart that displays 1 data point once per minute.
This chart has 1hr time markers...
so for every 60 data points, a 1hr time marker should be intersected.
Problem: I notice that my data points do not cross the 1hr interval after 1hr. Im wondering if my multiplier needs to be set from the chart properties?
If so, what do I need to set it to so that 60 data points intersect a 1hr marker.....I've tried different multiplier values that do not work .e.g "1" , "60", ".016"
please help!
J
10-24-2009 09:21 AM
Yes, set the property of the chart to 60. If you are working with a waveform datatype, you can set the dT to 60.
If you are still having problems, post your VI with your datasaved to the waveform chart and set to Default before saving and posting.
