How do u make a numeric control retentive
Very simply is there an easy method to make the numeric control retentive such that the next time you start up the vi the
previous data is retained?
(3,357 Views)
(3,353 Views)
Hi Mike thanks for that I guessed it may involve something more complicated than ticking a retentive box.
(3,350 Views)
If you need a simple solution.  Right-click the control, select Data operations then select make current value default.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(3,327 Views)
