How do you access events for scale range changes and cursor movements in graphs
Is there a mechanism for getting event notification of graph cursor movement and scale range modifications initiated by the user?
(2,757 Views)
The Event Structure in 6.1 is unable to monitor the events you described. The only way to do this is to place a property node in a loop. The elements in the node will be xscale.range and cursor.cursorposition. Read these property values with each iteration of the loop. Pass these values from one iteration to the next using a shift register(s). If the values change have the VI execute specific code.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,757 Views)
