How do you add more than two text labels to a slider?
I am attempting to add 4 values to a slider to enable the snapping action that is required. Using text labels will allow me to see this snapping action but I am unable to set more than two labels. I attempted to use the text labels property of the slider and send an array of text labels to it but it seems to only want to display two. Can 4 labels be displayed?
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,845 Views)
Place a slide control on the front panel, enable text labels (as the answer above says), select "min" in the text display and then right click on it, and select "add item after". This allows you to add as many as you want, you can rename "min" and "max" also. I posted this as an answer to your comment in the other question.
(2,845 Views)
thank you so much. That works great.
BJD1613
Philips Respironics
(2,845 Views)
