How do you average data being sent to a waveform graph?
I am reading a 2D .lvm file with the ReadFromMeasurementFile.vi. I would like to average each signal before passing it to the waveform graph in order to tamp down some of the background noise. Please tell me the best way to approach this.
(4,412 Views)
Use the Mean function or the Statistics Express VI
(4,401 Views)
I do not want to average the data as a whole. I need a running average.
(4,397 Views)
So you are not using the Read From Measurement File to read the entire file? You want to average one segment with the next? If so, you will use a shift register. I would not use dynamic data - just a 2D dbl array.
Message Edited by Dennis Knutson on 02-16-2010 02:01 PM
(4,389 Views)
Here is the code. How would you adust this so that the resulting wave forms are averages based on the previous 10 data points?
(4,381 Views)
There's no code there to modify. You have a single file read and a graph. It runs once and stops. You have nothing to average against.
I would suggest you first spend some time with the basic tutorials then do a search for 'running average'.
(4,369 Views)
Consider using a Median Filter instead of a running average:
(4,345 Views)
