How do you change display screens during program execution?
I would like to have a LabVIEW screen with a list of test Vi's to run and select one to be displayed.
Also, then return to the main screen.
(4,287 Views)
Accepted by topic author Robot215
looks like a project.............
Main VI Side:
creata a dropdown list (use ring/enum control) with list of test VIs...
now create an event  "value change" for the control.........capture the present value of the control.
use the attached VI as main VI...
and in SUb VI
on close event, get the reference of the main VI and use Property node "front panel open"...to get back to main VI
or you can close main VI when you cal a test Vi and re open the main VI when you close any test VI........
Message Edited by Anil Reddy on 09-13-2009 09:46 AM
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(4,281 Views)
The question I asked was my first at this site.  I am VERY happy about the response and how quicky it came.
I am new to this forum and wonder what is the proper protocol for responding to answers?
(4,263 Views)
You can click the Kudos & appreciate the answerer. Smiley Happy
- Partha ( CLD until Oct 2027 🙂 )
(4,213 Views)
Adding to this, don't forget to mark the solution when your problem is solved. You can select "Mark as solution" from the options menu at the top right corner of the post which you think is the best reply for your query.
Mathan
(4,211 Views)
