How do you change the directory location from the hieachy window.
Our DAQ system consists of 285 vi's. During development changes, some vi's were created and passed to the DAQ via a LAN connection. Pulling up the vi's at the DAQ has changed the desired path such that some come from the LAN virtual drive, while others are resident on the DAQ PC. All have been copied to the PC's hard drive. Viewing the LabView hiearchy, how do I change the directory for a few individual vi's to point at only the PC harddrive? I saw this done once, but forgot how and cannot easy find it in the help files.
(2,605 Views)
When this happens to me I temporarily disconnect the network drive or rename the network folder to force LabVIEW to do a search. If they're all in the same folder as the main VI, they'll be found automatically.
(2,605 Views)
