How do you change the name of an Xcontrol?
<meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11">
I want to change the name of an Xcontrol. I right click it and selects rename and everything seems to work fine until I restart LabView. The Xcontrol with the new name seems to have lost its connection to its abilities (Data.ctl, Façade.vi, etc.) and it looks like these abilities uses the old name as its prefix in the namespace. Is there a way to link the abilities to the xcontrol or another way to rename it?
Terje
LabView 8.5.1
(2,960 Views)
Which "component" of the XControl do you rename ? *.lvlib, *.xctl, ... ?
(2,955 Views)
I tried to rename the *.xctl.
Message Edited by Terje on 06-27-2008 05:06 AM
(2,954 Views)
You should do the rename in the LabVIEW project, make sure you save all the changed files (any part of the XControl should be changed).
It looks like you changed the xctl file on disk.
Ton
My LabVIEW Ideas
(2,927 Views)
