How do you clone propety nodes?
I have a ton of properties that I want to change based on program properties, and I am tired of going through the tedious process of creating a property node for each, selecting the property of each one, and changing each one to write.
How can I copy and paste a bunch of property nodes without creating some new thing? Same for local variables? How do you copy and paste a local variable with creating a new control/indicator?
(3,000 Views)
To make a copy withour creating a new control or indicator, select the property or local, hold down the control key, and drag the selected item to make a copy.
(3,000 Views)
select the existing property node / local variable.
Drag the the selected items with the mouse while holding the control key.
Then release the mouse. A new copy is created
(3,000 Views)
Great, Thanks!
(Wish I would have asked this one a long time ago!)
(3,000 Views)
