How do you control when a Listbox updates the view?
I have a problem, that when I highlight a line programmatically in a multicolumn listbox (wrting to the value property) it can take quite a while before you actually see it on the screen.
I can work around it by disabling and again enabling the symbols, but as the list is quite long, this gives a noticeable delay.
Is there a better way to force a screen update?
Using Laview 6.0.2
(3,015 Views)
Have you thinked about your problem regarding in another cause? For example, if you are using windows, you should put a small delay inside every while loop, to avoid your program to get all processor time, avoiding frecuent screen updates (including listbox).
Hope this helps
(3,015 Views)
Yes, I looked into that. Although the loops are susposed to be waiting already, I included some extra waiting time. Doesn't help.
The taskmanager shows only 1% cpu usage, so I don't think I missed something on that part.
(3,015 Views)
There was a bug in LV5.1 that corrupted the listbox display.
It was not updated until the user cliked on it.
It does not occur consistently so I don't know if it has been fixed in
6.0.2.
Try to replace the listbox control on the front panel with a new listbox.
Jean-Pierre Drolet
"Anthony de Vries" a écrit dans le message news:
506500000008000000471F0000-986697009000@quiq.com...
date?
> Using Laview 6.0.2
LabVIEW, C'est LabVIEW
(3,015 Views)
