How do you convert a constant analog pulse to an incremental frequency?
I am a very new to the Labview format. I am a graduate student in chemistry trying to update an old Raman spectrometer (from the 70's) to a digital interface.
I have measured two analog signals from the instrument.
One is a constant pulse signal of 100mV. This was used to drive a stepper motor on an old chart recorder. Each pulse corresponded to a single wavenumber----which, for every 5 pulses?-----would turn the chart recorder's knob one notch and allow the other signal to record the data for 5 wavenumbers.
The other signal ranges from 0 to 250mV. This is the signal of interest. It corresponds to the y-axis on the outputted spectra.
What I am trying to figure out right now is how to convert these analog pulses into incremental wavenumbers which correlate, in real time, with the other 0 to 250mV signal.
Should I use an Analog software counter program,
And then go from there, with synching my other signal to it?
 Can anyone tell me if I'm on the right track?
(3,035 Views)
Your application is quit interesting.
For the first question, Yes, You have to use the soft increment counter program which keeps on count up your incoming pulses of interest.
But I am not able to understand your second question. Could you please elaborate it.
MRK (CLAD)
(3,024 Views)
Yes,
First I want to be able to count the analog pulses and correlate them with a specific wavenumber (so I would start at a reference wavenumber, say, 200 wavenumbers---and then every pulse thereafter would correspond to 1 more wavenumber. So the first pulse would be wavenumber 201, the second 202, and so on).
This would establish by x-axis for the desired spectra of a chemical sample.
My y-axis comes from a different analog signal altogether. This signal ranges from 0 to 250 mV--and the the magnitude of this signal received, at a specific wavenumber, corresponds to data about the chemical sample in question---at that specific wavenumber.
So, after I first establish my analog counter program, I need to correlate this program with one that detects my y-axis signal. So my y-axis intensity corresponds with the proper x-axis wavenumber.
Does this clarify my entire project enough?
(3,016 Views)
Yah,
From your explaination what I understood and got the solution, I am explaining below.
As you said the X axis value is being plotted for every fifth data point, what you can do is, you can acquire the X axis signal say for every fifth second, and whenever this 5th value reaches, you can acquire one point of Y axis signal. Repeat the same operation till your process of sample investigation ends. Now you will be having two array of values of X and Y. Now plot this in an XY graph. So your software plotted graph and the instrument plotted graph will be the same.
MRK (CLAD)
(3,010 Views)
