How do you count number of changes?
I know lots of threads out there address counters.  I am trying to count number of changes for example.
T,T,T,F,F,T,T,T,F,F,F.
This would give give me count of 3.  I have done several renditions, but it would give me number of T or number F.  I am not sure what would be the best option.
Henry
(3,208 Views)
Here's one way that should work.
Message Edited by Matt W on 09-23-2008 07:46 PM
(3,199 Views)
Thanks for the quick reply.  Unfortunately, I simply get a stream of Boolens and it is not an array.  I did something simliar to that.  Hm... I wonder if I am missing something.  I will give this a try again.
Henry
(3,194 Views)
What is a "stream of booleans"?  Where are these boolean values coming from?  If it's not an array, how is the "stream" defined?  Please post the code you have so far.
(3,170 Views)
Here's a faster routine:
Ton
Message Edited by TonP on 09-25-2008 07:03 PM
My LabVIEW Ideas
(3,078 Views)
Mensaje editado por Luis_AM3C
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
(3,059 Views)
