How do you create a Labview Websocket client?
Objective: Use WiFi to transfer analog readings from an Arduino Yun to a Labview graphical user interface.
An Arduino Yun  provides Websocket server capability and is norm ally used with a browser.   But I don't how to create a Labview Websocket client.  Hence my question "How do you create a Labview Webcocket client?
Howard
Message 1 of 14
(11,266 Views)
This looks like it might be what you need:
http://www.lvs-tools.co.uk/software/websocket_api_for_labview/
this might also work out for you:
http://blog.evexiallc.com/
Message 2 of 14
(11,261 Views)
Thank you for your reply.
I am looking for no additional cost  Websocket capability.  The LVS Tools program costs $320.00.   I don't understand why the word Labview was mention on the Arduino WebPanel site.  As far as I could tell the author used second party software for an Arduino Websocket server and Javascript with a SVG library to to create a WebPanel.
I am going to keep looking for Websoket client capability for Labbview.
Howard
Message 3 of 14
(11,243 Views)
Have you looked at the http client functions? Do you simply want to read a web page?
Message 4 of 14
(11,232 Views)
No, I do not want to read a Web Page.  I want to use Labview's graphical user interface to capture and display analog data. However, instead of using a USB interface to a remote data acquisition device Wifi will be used.
I don't kow if Labview's http client functions will meet my requirements.  However, I have seen other messages saying a Websocket interface is much faster than a Webserver interface.  Hence I came to the experts in this forum to obtain Websocket capability and not some pokey slow webserver capability.
Howard
Message 5 of 14
(11,216 Views)
If you don't want to read a web page, then why did you say you wanted to use the arduino web server? If the device is just using tcp/ip writes, use those functions.
I think you need to better define the arduino interface.
Message 6 of 14
(11,212 Views)
Accepted by topic author hrh1818
Dennis - The interface is well-defined. Websocket is a standard (with some variations). It uses the web server, although it's not strictly serving HTTP connections.
I don't know of a free LabVIEW websocket client implementation. You might be able to pull apart the LabVIEW HTTP VIs to get some of the initial connection and handshaking logic, though.
Message 7 of 14
(11,206 Views)
Thanks. I misunderstood when he said a browser was used to view it.
Message 8 of 14
(11,200 Views)
Thanks Nathand,
Knowing there is no free Websocket available for Labview saves a lot of time and frustration on both sides of the question.
Howard
Message 9 of 14
(11,194 Views)
Again, I can't promise one doesn't exist. I've never needed WebSockets so I haven't specifically looked for an implementation. However, in several years of reading LabVIEW forums and blogs, I don't remember seeing a full, free, client implementation. There's the beginnings of a server posted here: http://lavag.org/topic/13777-labview-websockets-and-svg/ but I don't think it includes a client.
Message 10 of 14
(11,160 Views)
