How do you create a cubed symbol in a string?
I am trying to make a cubed symbol in a string. I was able to copy this text from a program someone else wrote, but can't figure out how they created it. It says its application font. Any suggestions?
Thanks.
(3,153 Views)
As far as I know there's no way to do super- or sub-scripts in LV.  Just type it up in word and copy/paste it.
(3,149 Views)
You can go to the windows character map, select the symbol, copy it, and then paste it into LabVIEW. Or if you are using a string control, switch to hex display and enter the hex value of the character (B3 in this case).
(3,146 Views)
I tried that and it didn't work. Any particular font?
(3,145 Views)
Thanks Dennis. I read lots of previous messages without any luck.
(3,133 Views)
In Windows, you can also usually type any ASCII character by holding the alt key, entering the decimal code on the numpad and releasing the alt key.
___________________
Try to take over the world!
(3,123 Views)
