Hi Jen
Yes it is possible to get the individual property nodes of controls that are in a cluster.
You have a property Controls[] in the property node of the cluster, so you get an array of control references. You just have to extract the single references to access the controls.
I attached a screen-shot, which shows this possibility.
Hope it helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
