How do you create a stand alone application using DAQmx when your application SCXI hardware isn't on the computer I am using to create the application?
How do you create a stand alone application using DAQmx when your application SCXI hardware isn't on the computer I am using to create the application? The DAQmx assitant won't allow me to create a task with hardware that isn't in my system.
(2,926 Views)
To do this, you simply need to set up the SCXI hardware in max as if it actually exists. MAX won't give you an error, I just programed a DAQmx Assistant for an 1102 on my computer and I do not have one.
(2,926 Views)
(2,926 Views)
You will need to have at least the DAQ device in your computer to add the chassis. When you add the chassis, don't auto detect the modules. You will have to add the terminal blocks and tell MAX which SCXI module will be connected to the DAQ device. Just make sure you don't test the chassis, when its not there.
I hope this helps.
Joshua
(2,926 Views)
