How do you drag and drop columns in a multicolumn listbox?
Hello Pax
i am also looking for something with same functionality as your listbox could you please post what you have done if possible in an version 15 or earlier.
Thanks in advance:)
Message 11 of 12
(521 Views)
Looks like I'm a bit late on the reply as well.
Sadly, I most certainly do not have those files anymore and haven't been doing as much with LabView as I once did. Considering how long it's been, I'm not even sure if this is an issue, or perhaps there are more elegant work around due to newer features. Haven't used it in at least 8 years or so.... but after seeing the Community Edition come out, I think I may start playing with it again and maybe pick up a DAQ as well.
As much as I've enjoyed the other work I've done, working with LabView was amazing. I'm hoping to see more visually-based programming environments that can compete with on the level of LabView, unlike most which are aimed at kids and very limited.
Wish I could have helped, and best of luck (if you even end up seeing this) 🙂
Message 12 of 12
(424 Views)
