How do you enable the Edit functions (Copy, Cute, & Paste) from the Run-Time menu?
When I try to use these functions in my application they are grayed and disabled.   I use the default Edit menu from the Run-Time menu;    Item Type: Application Item   Item Name: Edit, Item Tag: APP_EDIT [enable]   Item Name: Cut, Item Tag: APP_CUT [enable], Short Cut: Ctrl+X   Item Name: Copy, Item Tag: APP_COPY [enable], Short Cut: Ctrl+C   Item Name: Paste, Item Tag: APP_PASTE [enable], Short Cut: Ctrl+V  What am I doing wrong?
(2,709 Views)
The default value of copy,paste is its grey state u need to select something to get it enabled.
(2,694 Views)
