How do you find the path to a database, that is using the ODBC manager, with LabVIEW?
Ron, are you using the SQL toolkit? If so, you can wire the connection refnum to the 'Get Table Information' VI. This returns, for me at least, the fully-specified path(s) to the database file(s) containing the tables (in the zeroeth column of a 2D array of strings). If you're *not* using the toolkit, I'm not sure how to answer this - how are you using ODBC data sources...?
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(2,656 Views)
