How do you get length and postion of skeleton into an array?
Hi I am new to Imaq, and I was wondering how you could get a description of the skeleton(Skiz), such as length and position, into an array?
(2,581 Views)
IMAQ skeleton calls a dll and outputs only an image. There are no built in metrics. You can do the calculations yourself off the image array with a function called IMAQ image to array. It is found on the vision >> vision utilities >> pixel manipulations.
(2,581 Views)
