How do you individually strikeout text in a menu ring?
I have a menu ring with a list of options for the user. Once the option has been ran, I want the text in the menu ring to reflect this by being "strikedout"... I don't want it disabled, just incase the user wants to rerun the option but I want the menu ring to mark which options have been chosen. Is it possible to individually strikeout text in a menu ring - just like you can individually disable items using the appropriate property node?
(2,662 Views)
Blindon,
Elements in the menu ring are array elements. Each element in array must have the same font (This is a limitation of the definition of an array). So, you can only set all elements to be strikedout, not individual ones. (with the property node)
Zvezdana S.
(2,662 Views)
