How do you keep a VI running while waiting for user input?
I have a VI that:
1.  The user enters set points.
2.  The user starts the VI and the VI sends the set points to an external process via a serial interface.
3.  The VI  stops running.
4   The user waits for the external process to complete.
5.  Repeat sequence. Go to Step 1.
This works well except for one small problem.  Starting the VI in step 2 causes an external micro controller to reset.  During the reset it will ignore set point commands.  To get around this problem a delay has been added between when the VI opens the serial port and when the VI sends the set points to the external process   Is it possible to keep a VI running continuously in this type of application, thereby eliminating the start up and shut down of the serial interface?
If yes, how do you keep a VI running while waiting for user input?
Howard
(3,372 Views)
This is actually very simple, especially if you have the event structure. Have you taken any of the tutorials or looked at the examples that come with LabVIEW?
(3,363 Views)
What specific examples are you referring to?
Howard
(3,360 Views)
The ones for the event structure specifically. I'm posting from my phone. Look at the basic ones for user input. even a simple while loop with a boolean and a case statement would work.
(3,357 Views)
