How do you make an array of LED's mutually exclusive?
I have an array of led's on my control panel. Say 5 for sake of argument. I want only 1 led at a time illuminated.
If the user clicks on led 1 then led 1 lights and all others go out.
If the user clicks on led 2 then led 2 lights and all the others go out.
I don't want to use a radio button because the leds need to be pragmatically controlled by the program.
An simple example would be greatly appreciated. Simple please for the the labview challenged.
Thanks in advanced.
Message 1 of 9
(3,623 Views)
Try something like this.
Message 2 of 9
(3,615 Views)
I would still suggest a radio button.  You can replace the buttons with LEDs. Then use a local variable to write to the radio button terminal.
Aalenox,
Please do not post VIs with infinite loops. Add a Stop button.
Lynn
Message 3 of 9
(3,604 Views)
Lynn,
You need to get that .vi deleted and a version 12 uploaded.  Your version is 13 beta.
Message 4 of 9
(3,595 Views)
I have reported it to the moderator.
I made a last second revision and probably grabbed the wrong version when posted.
This one should be LV2012.
Lynn
Message 5 of 9
(3,588 Views)
Thanks for the help. I cant open your example can you resend in labview 11.
Thanks again.
Message 6 of 9
(3,547 Views)
Can you send me the exapmle for labview 11 thats what I have.
Message 7 of 9
(3,506 Views)
Message 8 of 9
(3,496 Views)
Thank you you are the man.
Message 9 of 9
(3,482 Views)
