Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do you put PPP on to RS422
Thales
Member
09-28-2005
09:44 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a new ethernet program which I require data to be sent to a RS422 duplex interface using a PC.
The interface data must be in the form PPP point to point protocol.
Does any body know how to do this with labview 6.1
0
Kudos
Message
1
of 2
(3,569 Views)
Reply
Re: How do you put PPP on to RS422
MarkLe
NI Employee (retired)
09-30-2005
05:34 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Thales!
To do what you want is possible, but you will need to write the protocol drivers for the PPP connection yourself.
The link below tells you how you go about serial communications under Labview 6.1, and gives you the vi's:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=BE4119351A4E5CA0E034080020E74861&p_...
And below are some links to documents about the PPP protocol itself:
http://www.ietf.org/rfc/rfc1331.txt
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/ppp.htm
Hope this helps get you started!
Mark
0
Kudos
Message
2
of 2
(3,546 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
