How do you read in and work with I24 binary data into LabView?
Hi there,
I have a program that is reading binary data in as 16 bits per sample.  I have some binary input files that were saved as 24 bits per sample.  How do I convert my old program to handle this data.  I realize that LabView doesn't have built in I24 conversion - how do I do this myself? I found a post that referred to using a boolean array to create your own 24 bit number - but I don't understand what that means...  Any help would be appreciated!
Thanks so much!
(6,381 Views)
You'll need to read the data into a string (or an array of U8), group the data into three bytes/characters, and convert to a 32-bit value that contains 24 bits of data. Here's one way to do it that I suggested in an older thread.
(6,356 Views)
Do you have the data in binary (0,1) representarion? This may help:
(6,341 Views)
@PA_UW wrote:
Hi there,
Thanks so much!
It means create an array with 24 boolean elements and process that as you wish
(6,322 Views)
Do you know the format of the saved 24-bit data?  Can you share some data with us, along with what you think the values are?  If it is I24, then every three bytes represents a 24-bit (signed) integer.  The first question to answer is "What is the order of the bytes"?  How do you want to represent these data?  The obvious choices are as an I32, but since the rest of your data is I16, you might choose I16, instead.
To convert I24 into I16, you can simply return the high two bytes.  To convert I24 to I32, you need to set a high byte that replicates the sign (saved in the most significant bit of the third byte).  One way to do this is to consider the third byte as an I8 quantity -- if it is positive, set the high byte to 0, and if it is negative, set the high byte to -1.
Bob Schor
(6,303 Views)
chembo - "binary" here does NOT mean a string composed of 1s and 0s. It means that the contents of the file represent the actual numeric data, rather than characters that form a human-readable representation of the data.
(6,298 Views)
Thank-you - I will give this a try!
(6,271 Views)
