How do you remove files from a library?
Is there any way to extract individual files from a library?  I downloaded a driver from an equipment manufacturer but the files are all bundled into a library.  The VIs were created with an older version of LabView and I do not need all of them.  I have updated the files I need and now I want to put them together with some other files in a project and create an executable.  Is it worth bothering with or should I just put the whole library in the project?
Thanks.
(3,860 Views)
Accepted by topic author CoreyNE
Easy way: Convert the .llb to a directory. Then you can simply move the files. Use the LLB Manager (Tools -> LLB Manager).
Hard way: Open each VI and then do a File->Save As.
(3,858 Views)
Excellent.  The conversion worked perfectly and was very easy.
Thanks.
(3,852 Views)
