How do you replace a VI in a library. I tried tools edit VI librairy and the only option is "delete".
Thanks T Tall
(2,969 Views)
Hi Tall,
Here is what I know. Go to the VI in the diagram that you want to replace-right click and selece the option "Replace" from the pop up menu. Then select the option "Select a VI" from the menu that pops up. Select the VI that you want to replace it with. You might have to save the vi with options as a liabrary in order to get the New VI in the liabrary.
See the picture attatched.
Hope it helps.
Good Luck.
-Pari.
(2,969 Views)
If you have the new VI open, all you have to do is "Save As" and choose the library as the destination. When you're asked if you want to replace the one that's in there, say yes.
(2,969 Views)
Thank you Dennis. Your advice solved my problem.
T Tall
(2,969 Views)
Use Tools/VI Library Manager
(2,969 Views)
