How do you return to a webpage after uploading file by a form in LabVIEW Web Services
I am using the code from https://forums.ni.com/t5/LabVIEW/Upload-file-with-LabVIEW-webservices/td-p/3172070 to upload a file to a LabVIEW web service. After submitting the form, in the browser window, I received the response
{"PermaPathArray":["C:\\Users\\Public\\Documents\\IMG_9416.JPG"],"size(s)":1,"TempPathArray":["C:\\Users\\XXXX\\AppData\\Local\\Temp\\2B37UAKR66T72V8A\\WebServices\\temp\\tmp4_3_1.tmp"]}
 The file is uploaded to the data server, but I am unsure of how to proceed from here, as the browser is now viewing
                 http://127.0.0.1:8001/MyWebService/upload
instead of the sending HTML file http://127.0.0.1:8001/MyWebService/upload.html.
 I have also tried something similar using a Fetch command in JavaScript with a POST method but get the same response.
Any help would be greatly appreciated.
(1,367 Views)
Need to reply with a redirect status (307 probably most likely) and set a header value of the location to redirect to.
~ Helping pave the path to long-term living and thriving in space. ~
(1,303 Views)
Accepted by topic author hekdude
It is a 301 response code on the Set HTTP Redirect.vi with the link to the web page you want to go to after processing.
Thank you for your help with this.
(1,286 Views)
