How do you save dynamic data type, from the DAQ assistant, for use in Excel or matlab?
Currently, I have the following basic VI setup to save Data from my PCI6221 Data Aquisition Card.  The problem I'm having is I keep getting the last iteration of the while loop in the measurement file and that's pretty much it.  When I try to index the data leaving the loop it gives me a 2D array of Data which cannot be input into the "Write to Measurement File" VI.  How would I save this to a useful Data/time step format?  I was wondering of a way to continuously collect the Data and then save it in a large measurement file that I would manipulate in Matlab/excel?  Am I using the wrong type of loop for this application?  I also noticed my Dynamic Data array consists of data, time, timestep and then a vector of the data taken.  Is it possible to just get a vector of the time change per sample alongside the data?    Sorry for the barrage of questions but any help would be greatly appreciated, and thanks in advance!
-Bryan
(5,566 Views)
There is a VI in the Express > Signal Manipulation palette called "From DDT" that lets you convert from the Dynamic Data Type to other data types that are more compatible with operations like File I/O....for instance, you could convert your DDT into a 2D array and use the Write To Spreadsheet File.vi.  Just a thought...
-D
(5,565 Views)
Ok I tried this out, and the issue I'm having when I convert my Data type is that the loop still outputs only the last iteration of the Data if I put the array outside the while loop without indexing or if I try to index the data on the edge of the while loop then this makes it a 3D array and I cannot save that to Spreadsheet.  So, do I need to have my DAQ Assistant VI inside a while loop?  I know Im missing something silly here.
(5,563 Views)
Ok, why not just stick the Write to Measurement File Express VI inside the While Loop, and choose the "Append to file" option on the configuration page?
-D
(5,560 Views)
yeah, see I knew I was missing something simple.  Thanks alot 🙂
(5,557 Views)
