How do you scale an image size down to fit window?
Hi, I have the need to show various images on my front panel depending on a user input, how do I load the image so it fits in the confine of my 2d image box? I cant see the zoom the fit option anywhere? m pictures are high resolution, I found an option to resize the box, but nothing to force the image to fit in a designated box without cropping parts off?
(398 Views)
There is a property node for zoom factor. You can calculate the required factor based on image size and container size.
(368 Views)
you may look at the slightly altered .vi from ravensfan from here
you need to scale your input image to the area size of image box
attached as labview 2020
how to use:
Spoiler
(280 Views)
Here's something I found on the board a long time ago
=== Engineer Ambiguously ===
(256 Views)
