How do you send <esc> char in a serial string in LabVIEW?
A customer of mine had the following request:
Scott,
We have run into a bit of a problem and would like to bounce this off you.  The new SW command set for our product test needs to have the escape <esc> char sent to it.  When using a console program like terra term or hyper term it works but I can't seem to figure out the correct way to do this in LabVIEW.
1> do you know if this can be done?
2> do you have to send the hex equivalent value <b1> to have this work?
Scott Rogers
Sr. DSM
Western NY
(6,382 Views)
Yes, set the character constant to \codes and send a \27 (since it is ascii 27 in decimal for escape).
Or set the constant to hex display and send 1B (it is not B1 like you said)
(6,380 Views)
Let me correct that.
It is decimal 27 which is hex 1B.
But you would send it as \1B in \ codes or 1B in hex display.
(6,373 Views)
for me the string command looked like    \x1b
(4,360 Views)
What string command?
This is a 9 year old thread.  Please put your reply in some sort of context.
(4,353 Views)
