How do you separate a 2D array so that you can scale channels for display?
I have an AI Read VI that is getting data from the DAQ board. It outputs data in a 2D array. How do I separate those values into individual channels so that I can scale them into engineering units on the from panel?
(3,199 Views)
You use the index array function to extract a column. For example, if you've scanned DAQ channels 0,2,4 and want the results for channel 2, wire a 1 to the column input.
(3,199 Views)
