How do you specify the units(volts), in the Percent to EGU vi
The PID (PID advance autotune)controller signal output is in percentage...and I need the signal changed to voltage to operater a pump (0-5V). I  used the  % to EGU Vi... but i dont know how to specifiy the volts...
any help?
(2,746 Views)
I don't think that VI cares what the actual units are, it just wants to know the min and max EGU for the % input.  So if your % is 0-100 you would just use 0 as min EGU and 5 as max EGU.  0-5 could be volts, Hz, Lbs, mA or anything else you can think of.
That or I don't fully understand the question.
(2,729 Views)
